I have an application uses basemapGallery, I just realized two of the basemaps have zoomlevel setting diffferent from the rest basemaps. Is it normal? Is there anyway to make the same zoomlevel for all basemaps?
Sorry, i dont have an answer, but I too have that issue with a custom "Home" button i built. the "view.zoom" level is different between my 2 basemaps. meaning clicking "Home" zooms differently depending on which basemap i have open.
Just echoing your issue. good luck!
p
According to this API page:
I guess that's the reason of your problem.
Thanks for the information. Your link is helpful.
But I am using only ArcGIS API.Within ArcGIS API, depending on which base-map I loaded in, the zoom level is different. I guess it was due to the basemap format "The basemap styles service provides basemaps with layers formatted as either image tile layers or vector tile layers. When you use a basemap in your application, the scale of your zoom level will vary based on the type of layer the basemap uses. "
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
