Editors App 内から編集者がデータを .csv としてダウンロードできるようにするリクエストを受け取りました。ServiceLine_editors ホストされたフィーチャービューの設定をエクスポート許可に変更し、Editors App の設定も変更しました。テーブルにはエクスポートのオプションが提供されていますが、選択すると処理は進みますが何もダウンロードされません。エラーは発生しません。何か提案はありますか? @AlexKabak<\/P>
Hi Chris,
I tested your scenario and I can't replicate the issue. I even tried it without checking the box for Export Data in the settings of the service. The Attribute Table widget seems to override that setting, and still exports the data if the capability is exposed. The export is placed in the Downloads folder on my C:Drive. It also shows the download at the top of the browser.
Did you save and relaunch the app before trying? From the screen shots it looks like you are testing in the configuration mode.
Hmmm...it's working when I'm signed in with the owner/admin account but not with Editor accounts.
Hi Alex,
I want to share with you what we found out. In our case, since we are not tracking replacement activities, we turned off all of the fields related to replacement. Once we made all of the fields included in the solution visible, we are now able to export to a .csv file. Not sure exactly why but we'll live with it. It's not a deal breaker for us.
