When I try to add a member it appears nothing on "Choose Methods" page pls help for this
Hi there,
If you could provide a bit more information I would be happy to help you.
1. What version of ArcGIS Enterprise are you using?
2. Can you consistently reproduce the issue?
3. When did this start happening?
Jessica
Hello @SamehMahmoud77
Including the answer to the queries by @JessicaLM. It would also be helpful if you share the following (If possible):
Additionally, have tried clearing the browser cache and trying to "Add member" after that.
Hope it helps!
-Archit
Greetings @SamehMahmoud77 In addition to the suggestion from @ArchitSrivastava of clearing the browser cache, I would suggest:
Let us know if any of the above helps.
