I need to have a draggable marker on the map something like how it is working in the example below -
https://developer.here.com/documentation/examples/maps-js/markers/draggable-marker
Thanks
Here is a sample of how to do this on a hold event.
https://codepen.io/odoe/pen/bLEroK?editors=0010
view.on("hold", ({ mapPoint }) => { view.hitTest(view.toScreen(mapPoint)).then((hitResult) => { if (!hitResult.results[0].graphic) return; console.log("hold event, now drag mouse to move graphic"); pointGraphic.symbol = selectSymbol; const pausePan = view.on("drag", stop); const move = view.on("pointer-move", updateGraphic); const up = view.on("pointer-up", cleanUp); handlers.push(pausePan); handlers.push(move); handlers.push(up); }); });
@ReneRubalcava how would you make the marker draggable without having to "long press" (hold) the marker? I'm looking for standard marker drag/drop behavior (hover over marker, get pointer, click and drag marker).
Thanks!
You'd need to add some logic to handle when you click to start moving it and click to stop. Here's an updated demo.
https://codepen.io/odoe/pen/VwVrxBJ?editors=0010
if (pause) { handlers.forEach((a) => a.remove()); handlers.length = 0; pause = false; return; };
Hi @ReneRubalcava,
I am trying in indoor map on floors, if I do drag and drop on floor it is going to ground floor, How can I place on floor.
Krishna
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
