Alaeddine, What you are seeing the first time is the my AttachmentRelateInfoWin widget and the last snapshot you are showing is the standard ESRI popup window because you have that layer defined with a esri popup as well. You should really use one or the other.Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).Follow the steps as shown in the below graphic:
Amy, Sure here is what I have for 2.4Don't forget to click the top arrow (promote).Follow the steps as shown in the below graphic:
