I am unable to load image services with ArcGIS online using Google Chrome version: 46.0.2490.71 m. However the image services load fine in Internet Exlplorer version 11.09600.18163.
Claire Inbody - it appears to be a mixed content issue. Chrome is basically blocking the layer from being loaded while IE allows it through (the behavior varies from browser to browser, and even version to version when the browser auto updates).
Try loading the app from the link below (http, instead of https):
http://ndor.maps.arcgis.com/apps/StorytellingSwipe/index.html?appid=8d57a3ffeab4485eb6565eac3feca5dc
Alternatively, you can add the image service using the https url - https://ags3.lincoln.ne.gov/arcgis/rest/services/Aerials/Aerial1964/ImageServer
Adding the image service url over https will help with the blank search issue you referenced above.
Hi Claire,
Can you provide more detail? For example, how are you trying to load your image services? Are you trying to add them as an item to your AGOL Organization? Or, are you trying to add the service directly to a web map? What errors are you receiving?
Jake,
I am trying to add the image service to the web map. I do search for layers, In A GIS Server. Type in the rest service url. It works in IE does not work in Chrome.
Chrome issue above.
IE- No issue.
I created a spyglass app and that app works in IE but errors out in chrome. I believe because it cannot read the image service I am using.
What version of IE are you using? I was able to reference the above URL in IE 11 and display the services. Also, have you tried adding the service by going to Add > Layer From Web? You can paste the entire image service URL there, i.e.:
Aerials/Aerial2013 (ImageServer)
Its chrome that does not work. I can get to work in IE- stated about version 11.
Get this error in chrome:
Sorry, I misread that. Are you able to upgrade to the below version? I was unable to reproduce the issue with this version.
I tried the application I created on the latest version of Google Chrome and Microsoft Edge and neither browser could properly view the spyglass app.
https://ndor.maps.arcgis.com/apps/StorytellingSwipe/index.html?appid=5fbc48e89cff4b908952fcc1107d75ef
It appears to still be a bug.
Claire
I'm having trouble reproducing this. Can you walk me through your steps? Here is an app I created:
http://countysandbox.maps.arcgis.com/apps/StorytellingSwipe/index.html?appid=d35a86da4477406e94c1434acc9c3cca
Steps:
1. Open web map
2. Added a layer (in this example, it's a tiled layer)
3. Saved and Shared with Everyone
4. Created the app using the Spyglass and one web map
Are you able to open the above web app in Chrome or Edge?
You are able to see the spyglass app with the 1964 imagery?
I am using two web maps, one with the world imagery (spyglass) and one with the 1964 image service. I cannot get the application to run properly in chrome, edge, or safari.
As stated above I loaded the image service and then saved the map. Then created a spyglass application.
Yes, I was able to get this to work with the 1964 imagery as well:
http://arcg.is/1QGDAet
1. Opened a new web map
2. Set the basemap to World Imagery, saved, and shared with Everyone
3. Opened a new web map and added the 1964 imagery by going to Add > Search for Layers > Specified the ArcGIS Server URL
4. Saved the web map, shared with Everyone, and then created the web application. This time I chose to use two web maps
Note: all of the above steps were performed in Firefox
Does the above application work for you in Chrome?
It fails in chrome(version 46- still cant IT to install the new version-wonder why I can get the firefox version to open but not the IE one) after created in IE.
http://arcg.is/1PPbHB8
The above fails for me as well in Chrome version 48.0.2564.109. You may want to follow up with Tech Support so that they can log this bug.
Chris,
Perfect. Thank you for the information, you are correct once I added the image service via https I do not have any issues in chrome.
