I am using Survey 123 and have created my survey to collect images. Is there a way to get these images to appear in my Dashboard as the photos are collected in the field?
Hi Rach,
I'm assuming there are points being captured with the images? These should be appearing as attachments at the bottom of the popup when you click on points on the map (if configured in the web map) - you could also have a "details" pane in your dashboard with your feature info that you can configure to show the images too.
Josh
Hey Josh,
Yes, points are being captured also within the survey and I like how the "details" pane looks with the pictures, thanks for that. I also have added a table to display my survey questions. Is there anyway to connect the "table" and "detail" panes so that when I select the information in the table the corresponding pictures appear?
Hey Rach,
Yeah so if you go into configuration for the table and look at "actions" you can set it to filter the details widget based on the current selection!
