Just what it says on the tin. When attempting to do a georeference of a raster a drop down menu which would allow to save the georeference is absent. I have tried everything and nothing seems to be working. Is it the version I am using (10.7.1) or is it something else?
Sandy - if you drag/drop the Georeferencing toolbar from it's current location and into your Data View (map), do you know see the Georeferencing dropdown. Where you toolbar is currently located, it looks like the left side is cut-off for some reason.
