How can I see the list of rasters in ArcGIS Pro participating in a mosaic dataset? ArcCatalog had this functionality.
There is a GP tool - Export Mosaic Dataset Paths (Data Management) that would generate a table of MDS data paths. Would that work?
Add the Mosaic Dataset to a Map View in ArcGIS Pro first, then right-click and open the attribute table. In the table, you see a Name column that lists all the raster datasets participating in the MDS.
but it doesn't show the files path?
thanks, that is what i needed. Is there any way to just see the list of rasters instead of exporting them into a file?
