Hello
I looking for a way users can add Latitude and Longitude in survey and then map show the location? is it any way users can manually type lat and long to appear on map (geopoint)
If you do not want to store the geopoint in the feature layer, set the bind::esri:fieldType column to null.
Remember you can also use your own web map or mobile map package for your geopoint question as described here.
@IsmaelChivite How can i add the lat and long on the report? I want to bring the lat and long of the point to the report but also keep the point captured by the survey
