Hello,We have registered the Portal for ArcGIS, ArcGIS Server, and Database component in ArcGIS Monitor 2023 however we are unable to see the published Hosted feature layer in the Services component.Can someone please help with this?Thanks!
Hello,
The current release of ArcGIS Monitor does not collect metrics for hosted feature layers. This will be included in a future release of Monitor.
Josh
Hi @VarunKakkar, Just to add onto @GeoJosh's post currently ArcGIS Enterprise portal does NOT report metrics on hosted feature services. I believe this will be added to the ArcGIS Enterprise 11.1 release.
Once these metrics are available, then ArcGIS Monitor will be able to report this info.Hope this helps,
Hi Derek,
Is it safe to assume that metrics pulled from an ArcGIS Server that has a hosting role within ArcGIS Enterprise is not based on data from hosted services then and only from system's geoprocessing services and any non-Portal published services then?
Hi @MichaelKarikari1,Yes, I think that's a fair assessment.Hope this helps,
Hello, have there been any updates on this now that Enterprise 11.1 has been released? Will hosted feature monitoring be available in ArcGIS Monitor soon?
Hi @adeqgis,We anticipate that support for reporting metrics for hosted feature services will be in the next ArcGIS Monitor 2023.3 release. We are actively testing this capability now.Hope this helps,
Thank you Derek, that is great news. Excited for it.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
