I have a hosted feature layer that I created with Survey123 Connect. It has 3 Date fields. I have done some of my data collection and went to begin configuring my Experience Builder app today. I noticed it wouldn't allow me to add my data as a source in the time slider widget. When I checked the Web Map, it won't let me enable time on the layer. What is blocking the time enablement? Is it not enough data (only ~5 records collected so far)?
Have you enabled time at the Hosted Feature layer settings level?https://doc.arcgis.com/en/arcgis-online/create-maps/configure-time-mv.htm
The Time Settings window appears.
That's the ticket! Thank you!
