Hello -
I have created a model that simply deletes data from a feature, then appends data from another. It runs every night.Today, we have found the issue that curves in the original data are being converted to lines. Has anybody else had this issue? Is there an easy solution that I may be missing?
Thanks!
Featureclass in a file geodatabase is the destination? What is the source?
have you set this in the append tool's environments?
Maintain Curve Segments (Environment setting)—ArcGIS Pro | Documentation
Oh shoot - that's my answer. Thank you!
Dan:
Was this not an issue with models/scripts created in ArcMap?
