皆さん、こんにちは。私はEsriのディストリビュータースタッフです。リタイアされたEsriのオンラインコースにアクセスする方法があるか知りたいです。<\/P>
ありがとうございます<\/P>
Hi @DasheEbra, once a course is retired, there is no way to access it on Esri Academy. Since you are a distributor, we recommend you contact ITP (ITP@esri.com) and put in a request with the name(s) of the retired material(s) with a justification of why you need it. The Curriculum team will then determine if it's possible to provide the materials. Hope that helps!
