hello, while i was trying to edit the layers in my arcgis pro (3.0) the application stopped working.
i tried to send a report and restart the app, it didn't work.
is anyone faced the same problem, and what was the solution?
Hi - I have the same problem. When I hit the symbology indicator box directly below the name of the layer a message comes up saying the application has stopped working. This applies to all layers. I have tried exporting the data to a new layer, deleting the old layer, still the problem persists
This is caused by a Microsoft .NET update. There are patches for 2.8, 2.9, and 3.0 that fix the issue. Refer to:
Recent Microsoft .NET Update Resulting in ArcGIS Pro 2.8 and 2.9 Crash When Changing Symbology (esri.com)
hi Daniel - you're correct - I just updated to 3.0.1 and the problem has stopped
Cheers
Richard
Hi there I am using ArcGIS Pro 3.0.3 and I keep getting an Application Error that is causing ArcPro to crash?
Is anyone else encountering this issue? Thanks.
