Is there a way to limit the extent of a webmap? I have a custom basemap that only cover the area of interest and I would like to prevent the user from panning / zooming around the whole world and keep them within the limit of the basemap.
I am looking for this solution in either web map or Experience Builder... Does anyone have updates if it is aavialble?
Hi, when will this function be included in the experience builder UI?
Oh interesting, I see that embedding web apps doesn't working using the + option, but have you tried the Add > Embed option? I was able to embed a web app as background app, that was interactive with the navigation boundary.
Thanks @CarmelConnolly that solution would work for a standalone app. As I understand it web apps cannot be added to the new storymaps in sidecar or slideshow mode. I suppose one work around would just be to make the maps non-navigable and embed an app with Naivgation boundary set at the end of the storymap.
Update! Just realised I can "embed" an app in sidecar
@CarmelConnolly is right, the web map spec currently does not have a property to set the max navigational extent.
Hi Oliver,
I don't believe this is possible in the webmap itself but it is a configurable option in some of the Instant Apps applications through a 'Navigation boundary' setting: keeps the area in the map in focus by using a navigation boundary or disabling the ability to scroll.
https://<yourorganisationname>.maps.arcgis.com/apps/instantgallery/index.html?tab=browseAll
You can narrow down the options by searching for 'Navigation boundary':
In the app, disable 'Express' mode and the 'Navigation boundary' will be an option through the menu. This is what it looks like in the Basic app:
