私のMy ESRIに組織があります。ユーザーをESRI Academyトレーニングに招待すると、ダッシュボードではアクティブになっていますが、これらのユーザーはトレーニングにアクセスする権限がありません。<\/P>
この問題を診断してください。<\/P>
<\/span><\/P><\/P><\/span><\/P><\/P>
When you add users to ArcGIS Online organization, you have to authorize on their accounts for ESRI training!
If you are adding people manually or sending out invites - in the Set members properties part, check the option for Esri Access, and that should fix the issue
If it's a user that was already created - an admin can turn the setting on in the user's profile!
Hello,
Please contact support https://www.geomatic.ma/fr/contact for help administering your ArcGIS for Personal Use license.
Best regards!
Thank you for your reply @SaraJL
In my organization ArcGIS Online I can just allow one member.I acquired an ArcGIS for Personal Use license which gives me the possibility of guest up to 1000 users in ESRI Academy.
