Field Maps ios App. After downloading an offline area, the layer fails to load with a error code 20 - no data.
I needed to recreate the feature class. This resolved the issue.
I have discovered that there is an issue in attempting to create the polygon feature and the feature editing template in ArcMap. I am getting closer to identifying the issue. Anyone have any recommendations?
Hello! I am running into the same issue that you mentioned above. I recreated the feature class, but I am still receiving the same error. Did you have to change the schema or anything else about the feature class to get this to work? Is your feature service hosted? Thanks in advance!
in my case, the solution is give geodatabase user full access to feature class that published as services
When you say "recreate the feature class" do you mean you actually recreated it from scratch? OR did you just remove it from your map and add it back in?
