Good morning everyone,
I'm trying to create a summary report and I'm receiving an error I've not seen before when uploading my summary template. The error is, "Error: An error occurred when splitting the report template. Cannot insert a node of this type at this location.".
I'm including my template as well. Perhaps I'm missing something that's not immediately obvious.
Thanks in advance!
Did you find a solution to this error? I am getting the same one and do not see anything online about it.
I am getting this same error. Anyone find a solution? I've looked everything online and I can not find any helpful resources. Thanks!
I am also having this issue- did anyone find a solution?
I had a similar error message: "Error: An error occurred when splitting the report template. Cannot invoke "com.aspose.words.Node.remove()" because the return value of "com.aspose.words.NodeCollection.get(int)" is null"
By reverting back to the original template and slowly checking the syntax as I made edits, I deduced that it was because I had tried to put data into text columns in my template.
I hope that helps!
What would you recommend for a table that needs to remain static but has two fields that need to be generated inside of it? I am getting the same issue with my table.
