We want to test both GIS and Image Server in a single machine. It seems we've to install GIS Server and Image server in different machine. Can we install both GIS and Image server just for testing?
Thanks for the info.
How do you re-license ArcGIS Server with an additional role? I'd like to license it with both the GIS Server and GeoEvent Server roles in a test setup. Does it need an authorization file with both authorization numbers?
You don't, you just re-license the already installed ArcGIS Server software to add the Image Server role to it.
Thank you for your response. ArcGIS Server already installed on dev server. How can we install again in the same machine for 'image' server role?
Hello there,
For testing, this should be completely fine. I would just recommend taking into account the potential resources you may need and compensating for it appropriately.
