I have made a website with arcgis api for JS , now i have to make a mobile app, so my question is can we use arcgis with flutter.
Hi Rajni,
The ArcGISRuntime SDK for Android does not support Flutter. There are discussions with ArcGIS Runtime product management about supporting/integrating with Flutter but no specific plans have been made yet.
Yesterday we released the first beta of the ArcGIS Maps SDK for Flutter, targeting iOS and Android. If you haven't already done so, please jump on over to the early adopter site and sign up! See this blog post for more details.
Any news on support for Flutter in ArcGIS?
How can we implement feature layer on arcgis map in flutter? is it supported ? can you pls help me with the alternate on this.
Hai @SoniaGupta yes it is, you can use ArcGIS rest Service and show up the feature layer with flutter_map for support the map and flutter_svg for support the layer.
I have used below code -
layers: [TileLayerOptions( urlTemplate:'https://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer/tile/{z}/{y}/{x}', )When entering feature layer URL -https://services2.arcgis.com/XYXYXYXYXYXYXYXY/arcgis/rest/services/GridMap/FeatureServer/2 But its not showing layer on Map. Please share some link or sample code to work.Note- XYXYXYXYXYXYXYXY is the key.
Any updates on this? In my last conversation with ESRI SDK product management, there was no plan to support Flutter. I hope this has changed, or will in the very near future. My mobile dev team has had tremendous success with Flutter. Setting aside for the moment that we don't have to maintain 2 (or more) code bases for each app, it takes about half the time to write an app in Flutter vs. native. We are in the process of rewriting almost all apps in Flutter. The app with our largest customer base (over 200k) is currently leveraging the runtime SDKs. If there is not a plan for ESRI to support Flutter, we will need to migrate away from ESRI and ArcGIS.
Hi @JakeShapley ,
I do not have any information regarding ArcGISRuntime for Flutter, but wanted to offer an alternative. We have a product, ArcGIS AppStudio, that is a low-code solution for building cross platform (iOS, Android, Windows, Mac, Linux) applications using the Qt QML language and the ArcGISRuntime API for Qt. Please feel free to message me if you have any questions regarding it.
Best regards,
Trevor Frame
We have created Flutter plug-in package for ArcGISRuntime SDK for Android and iOSThis works and we have been able to use ArcGIS in Flutter without any problems.Attached screenshot of the app showing a map with some extra layers onWe also use https://github.com/Esri/arcgis-runtime-toolkit-iosandhttps://github.com/Esri/arcgis-runtime-toolkit-androidin the app
Hi @TrevorFrame ,
I appreciate the reply. Unfortunately, AppStudio really isn't a solution for us. Our apps are highly-customized and interact with our in-house APIs. Even the way we leverage ArcGIS Server (per the Enterprise team) is novel. Ideally, ESRI would start supporting Flutter, to support the huge, growing community.
Best,
Jake
Hello @snlasystem ,
I really appreciate you reaching out. I am very interested in taking a closer look. Have you published it to pub.dev or is it available elsewhere? Feel free to DM me, if you'd prefer.
Hi @snlasystem,I would also like to integrate Esri maps into Flutter.Does your solution also work offline?I am also very interested in taking a closer look...
Jan-Henrik
Hello
It works offline now, but we think the download is to slow. (after download it is fast)We are working on adding support for this: https://developers.arcgis.com/documentation/glossary/mobile-map-package/That will make it betterYou can download it here:https://github.com/valentingrigorean/arcgis_maps_flutterJørgen
Hello,
I figured I would take a minute to provide an update on this. I have been leveraging this plugin to rewrite our native iOS and Android fishing regulation apps in a single code base, with the same application logic (huge win!). Also, with Flutter, unlike some other cross-platform frameworks, I only have to write a single UI, and (optionally) tweak platform-specific widgets, thanks to this plugin. I would also note the developers are super responsive and quick to fix any bugs. This plugin meets 90+% of my app's needs at this point. I have bundled a replica.geodatabase file for offline data access. I am adding downloading and syncing (via ImportDelta) a delta.geodatabase file. It looks like the plugin already supports this. It also looks like it supports offline .tpk and .vtpk basemaps, currently. I will be adding a bundled .vtpk shortly. Just wanted to say thank you! This is the plugin ESRI should start supporting.
