Can a Capture field be removed from a button or disabled? Our project is built from a layer feature that has a field called "Verified" that we don't want QuickCapture users to record (see image). It defaults to "No" but we don't want users to be able to change that. The records will be "verified" later through a web map.
Hi @GregGeise1 The fields are read from the target feature layer of the button, Designer can not add or remove fields, it needs to be done from the feature layer level. If you do not wish to capture data for this field, you can leave it empty in Designer and it will add a null value to this field when user captures data.
Thanks Mandy_Li!
