ArcGIS for SharePointを使用して、SPリストをAGOLのホストされたフィーチャ サービスに接続し、リストが更新されるとフィーチャ サービスも更新されるようにすることは可能ですか? <\/P>
または、これはPower Automateを使用して実行できるワークフローですか?<\/P>
Thanks Tim, I did indeed get this working using the ArcGIS connector.
My flow in Power Automate uses the Sharepoint [When an item is modified] trigger to pass the updated row to the hosted feature service using the ArcGIS [Update a record in a feature layer] action.
I found that I needed to be the owner all of the resources, including the SP List, hosted feature layer and flow to make it all work.
Yes, there is an intermediary step between knowing there is a change and updating the hosted layer. See attached.
1. When an item or a file is modified
2. Get changes for an item or a file
3 Update a record in a feature layer
That will do all changes. I'm only usually looking for certain changes, so after step 2, I put a condition in to check if the Status column has changed and then if the status column = a certain value. If those things are valid, I make changes to the layer. That may or may not be useful depending on what you are doing. In this case the flow fires a lot more (whenever there are list changes) than updates to hosted feature layer take place. Because if the status isn't what I want the flow just does nothing. So it can be confusing when reading the logs as it runs often.
Yes, would be interesting to see the Power Automate workflow @ACrateau.
Can you share an example of your Power Automate workflow? Is there an intermediary step between the [When an item is modified] step and the [Update a record in a feature layer]? I want to JOIN the Sharepoint list and feature layer based on a certain field and update other fields in the feature layer with the changes from the Sharepoint list.
Thanks
Hopefully you got this squared away. I was using survey123 trigger to create a new list, but just glancing and it looks like there are 3 feature layer triggers in power automate related to agol.
So looks like this will keep your list updated. Doesn't seem like a connection per se, but at least your 'copy' list will reflect the data in your agol layer.
-Tim
