こんにちは。
ドライブ時間などを調べる「解析」機能は、「新しい」Map Viewer でいつ利用できるようになるか、ご存じの方はいらっしゃいますか? ありがとうございます。
Jim
It is still in active development. It wont be rolling out with the fall update unfortunately but is planned for the first release of 2023.
Hey Jim,
Analysis tools will be rolling out with the update of Online which is planned for tonight. You should see it tomorrow.
Okay, thanks Russell.
Hi Russell;
I received an email from Brian Baldwin that the Analysis tools are now available for the (new) Map Viewer. I logged in to ArcGIS Online but I don't see an "Analysis" icon on the right-side options list (see attached). Do you know when the analysis functions (and icon) will be available? Thanks.
Excellent! Thank you.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
