ArcGIS Pro Enterprise 10.9.1: Compressing an enterprise geodatabase (SQL Server) fails to transfer the content of delta table into the base table,
I have already posted this issue in the past but got no root solution.
Not sure why compressing an enterprise geodatabase (SQL Server) fails to transfer the content of delta tables (Add\delete) into the base table. I expect that the delta tables should get blank while all edits are transferred to the base table
What could be the issue here?
