こんにちは!
都市部の地面の画像を処理しようとしているのですが、画像が正しく整列していません。DroneDeployで画像を処理してみたところ、ほぼ完璧な成果物が得られました。私の職場が進んでいる方向性として、オルソ補正にはDrone2Mapを使いたいと考えています。オルソ補正画像を得るために見落としているステップや改善できる点はありますか?
Jessica, Looks like you're referring to the Circle and just up the Left diagonal of > Landscape area ?? From your example, it appears the Orthomosaic passed and created...... so perhaps Control in Area (not seeing any in the screen shot provided ??
Under the Processing Options -->2D Products --> Image Collection "and" Orthomosaic, did you have BOTH the Color Balancing and Seamlines toggled on..... and also Enhance Orthomosaic ?? Suggestion.
Similar issue with mine. Is there a way to georeference the drone imagery after the flight? Is the imagery off because of some settings on the drone?
Jessica - sorry for the delay - I did not see your message. Have you gottn this resolved already?
It appears you have the Standard license, is that correct? We sometimes see minor misalignments but typically not as much as you show in this screenshot. Can you confirm you had ~70% overlap or more, both along and between flightlines? I you have less overlap, you may find these sorts of difficulties.
Did you us "None" for the orthorectification setting? If your project has significant terrain changes, you may want to use the "Sparse point cloud" instead of "None".
If you still need help, please contact Tech Support.
Cody B
Chuck
I'd have esimilar comments and questions re: my response to Jessica above.
