ArcGIS Pro 3.0.1: How the management of data reviewer is performed in ArcGIS Pro?
In ArcMap, the reviewer, corrector, and validator are used to commit their work as per the screenshot below. I’m not sure how this can be managed in Pro
You didn't indicate whether you read the documentation or saw the tutorials
Get started with Data Reviewer—ArcGIS Pro | Documentation
Implement automated quality control—ArcGIS Pro | Documentation
I went through the documentation and videos available but appears not to be sufficient to work with all the “manage quality” components
The lifecycle management workflow for Reviewer-created errors (in both Batch Job and validation attribute rule workflows) is the same as it was in ArcMap (albeit in a different user experience). This topic outlines the various "paths" that are available in the different phases.
