error 002846: the attribute rule type is not supported in the input workspace
That massage show when i creat anew validation rule
Hi @waeltaher,
Thanks for sharing your geodatabase!
It appears that your data does not currently meet the requirements for implementing a validation attribute rule.
To implement a validation attribute rule, you will need to enable Global IDs and Editor Tracking on the data source(s). Here is a link to the documentation for reference:
Once these requirements have been implemented, you should be able to create and save a validation attribute rule.
this is the DATA BASE
Can you zip up your GDB and share it so we can try?
the data set is center line ( polyline type ) it show the same erro although i try diffrent valaiation rules it show the same error massage , as showen in the picture blew .
my work space type is file geodatabase
What's your input workspace type? Validation attribute rules are supported for file and mobile geodatabase, and enterprise Geodatabase that is branch versioned.
https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/overview/validation-attribute-rules.htm
Does the dataset meet the requirements for using validation attribute rules? Here is a doc topic that outlines the requirements for implementing attribute rules.
