Hi, is there an easy way to connect to a postgres database (hosted through AWS) to ArcGIS Online?
You have to publish data to ArcGIS Online. There is not a way to connect an "external" DB (as far as I know). The published data is hosted in ArcGIS Online.If you need this DB to be published, then I would recommend using ArcGIS Enterprise and referencing the services in ArcGIS Online.
@George_ThompsonI am making a ModelBuilder model which will use a table from the PostgreSQL and perform some calculations (tabulate intersection, joins, etc). If data changes in the database, will the changes automatically appear in ArcGIS Pro? If not, how can I make sure changes appear without reconnecting the database
You would need to create and publish a DB view (via ArcGIS Enterprise or ArcGIS Server) if you want the changes to show up.
If you use a model, the data will be updated after the model is run, unless you script it to look for updates.
@George_Thompson can you tell me what libraries I would need to connect/update the database in ArcGIS Pro notebook? Also, I'm no longer use a model builder instead I will be connecting the table from the database with a feature class
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
