using ESRI.ArcGIS.Client; using ESRI.ArcGIS.Client.Geometry; namespace MySilverlightProject.Controls { public class CustomFlareClusterer : FlareClusterer { protected override Graphic OnCreateGraphic(GraphicCollection cluster, MapPoint point, int maxClusterCount) { int elementIndex = 0; // Loop through the Graphics in the cluster, and add an ElementIndex attribute to each item foreach (Graphic g in cluster) { // First, check to see if the Graphic object already contains the ElementIndex attribute, and reset it if necessary. // This is necessary to handle cases where the Graphic object was part of a large collection of Graphics prior to // the user zooming in to get to the Flare Clusterer object on the map. if (g.Attributes.ContainsKey("ElementIndex")) g.Attributes["ElementIndex"] = elementIndex; else g.Attributes.Add("ElementIndex", elementIndex); elementIndex++; } // Now pass our modified GraphicCollection object, "cluster," into the GraphicClusterer OnCreateGraphic method return base.OnCreateGraphic(cluster, point, maxClusterCount); } } }
private void Map_MouseLeftButtonDown(object sender, MouseButtonEventArgs e) { // Attempt to case the clicked object to an Ellipse object Ellipse ellipse = e.OriginalSource as Ellipse; // Get a reference to the map's GraphicsLayer GraphicsLayer graphicsLayer = Map.Layers["DynamicGraphicsLayer"] as GraphicsLayer; GeneralTransform generalTransform = Map.TransformToVisual(Application.Current.RootVisual); System.Windows.Point transformScreenPnt = generalTransform.Transform(e.GetPosition(this.Map)); var graphics = graphicsLayer.FindGraphicsInHostCoordinates(transformScreenPnt); foreach (Graphic g in graphics) { // If the Graphic object clicked by the user is not part of a cluster... if (graphics.Count<Graphic>() == 1) { // Add processing code here. What I do is navigate to another page, and pass in the associated Id Attribute of the // Graphic object that was clicked. // Exit break; } // Check to see if the object clicked by the user was actually an Ellipse object. The object will be an ellipse if // the user clicked on one of the "flares," but that may or may not be the case if they clicked on the center Graphic // of a cluster, or if they click on a cluster that contains too many objects to be a FlareClusterer. if (ellipse != null) { if (ellipse.Name.ToLower() == "mainsymbol") { // The Ellipse that represents the center of a cluster was clicked, so what I do here is create a list of // the "Ids" for each Graphic in cluster. The Id is pulled from the Attributes. // Add processing code here. I display a panel on the side of the map with a list of people at the location clicked. } else if (ellipse.Name.ToLower().StartsWith("elm")) { // Each "flare" in a cluster is an Ellipse with a name that is "elm" + an index starting from the right-hand side // and going around clockwise. The first "flare" will be named "elm0," the second "elm1," and so on. Using that // information, we can match our ElementIndex up with the element clicked to figure out which "flare" within the // cluster was clicked. All we need to do is prepend "elm" to our ElementIndex and compare it the name of the // Ellipse that was clicked. if ((g.Attributes.ContainsKey("ElementIndex")) && ("elm" + g.Attributes["ElementIndex"].ToString() == ellipse.Name)) { // Add processing code here. What I do is navigate to another page, and pass in the associated Id Attribute of the // Graphic object that was clicked. // Exit, since we've found what we were looking for. break; } } else { // Add processing code here. I display a panel on the side of the map with a list of people at the location clicked. } } else { // This should be used to handle the cases where the user clicked on a GraphicClusterer, but the actual click event // was fired for a child of the Ellipse object, such as the text containing the number of items in the cluster. // Add processing code here. I display a panel on the side of the map with a list of people at the location clicked. } } }
