こんにちは、
現場の 3D モデリングを含む ArcGIS Pro のマップ パッケージ ファイル(.MPKX)を受け取りました。ArcGIS Pro 2.9 で開きました。
ArcGIS Online または ArcGIS Enterprise で作業できるように、ここからシーン レイヤーを作成するにはどうすればよいですか?
ありがとうございます。
What kind of data is it(points, BIM, multipatch)?
Are you viewing the content in a scene in Pro?
Do you have an organizational account or what version of enterprise do you have?
Some helpful doc
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/share-a-web-scene.htm
https://pro.arcgis.com/en/pro-app/latest/help/sharing/overview/web-scene-layer.htm
What kind of data is it(points, BIM, multipatch)? It's BIM most probably
Are you viewing the content in a scene in Pro? Yes. as local Scene.
The problem when I use the option to share it as a layer package so I can then view it in ArcGIS Online, I got the following errors despite the analysis step is successfully completed. It seems I'm missing something
you will need to share this as a web scene and publish a scene layer during that process. layer packages are not viewable in web apps.
This is what I know, but the only options displayed are presented below. and ArcGIS Online doesn't open .Lyrx files.
Do you have an organizational account with publishing privileges
Yes I do.
When you go to properties on the BIM layer what is the source for it?
Hi, Sorry for my late answer .
I'm note exactly sure what is your question about, but hopefully the below screenshot would be providing that.
I hope now your can provide assistance to know why I can't publish it to ArcGIS online/
That is a scene layer package. You can do either Share Web Scene which will upload that package and publish a scene layer from it or upload that package directly through ArcGIS Online> My Content > Add Item
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
