ArcGIS Pro 2.4.2: How to display the full path of the aprx file on the title bar?
It would be great if an option is made available to display the full path of the aprx file on the title bar. For example, this option is available in AutoCAD
No sure regarding the status on this idea
Hi Jamal. The status of this idea is currently Open. See ArcGIS Ideas Submission Guidelines and Statuses - Esri Community
ArcGIS Pro 3.0: An option to display the aprx path (location on the drive) on the title bar,
It would be great if we got an option to display the aprx path (location on the drive) on the title bar.
This option is already available in AutoCAD and FME, for example
Related
ArcGIS Pro 2.4.2: How to display the full path of ... - Esri Community
Status : Under Consideration
My bad. I forget myself that I have already posted this idea long time ago!
Hello @JamalNUMAN,
Thank you very much for your idea. In ArcGIS Pro 3.4, the project title has a dropdown, which will show you the path of the project .aprx file (with middle ellipsis if the path is long), the last modified time of the project, and a button for copying the path easily:
We hope this solution satisfies your need.
Thanks you again for your input, and we look forward to more of your suggestions!
投稿、コンテンツのフォローなどにはサインインしてください。初めてですか?無料で登録しましょう。
