Looking For parks and recreation .Stylx or .svg for map we are creating. Need icons like disc golf, soccer, baseball, swimming etc...
how do you download or add the script for the stylx. there was no file just a code
I will check out those two sights , thanks
thank you for the info, ill keep checking through AGO
If SVGs are your thing, you can check out sources like Material Design Icons or Wikimedia Commons.
In the former, you can export any icon as SVG. In the latter, you can specify file type when you search. There are plenty of SVG icon packs out there, just be sure to check their licensing and attribution requirements, as some sources will require attribution.
Hi Mark -
If you are using ArcGIS Pro - you might be able to find what you are looking for by signing in to ArcGIS Online
Click Portal and the ArcGIS Online Icon
Search for parks type:style
Then you can look through the style, you might have to try different combinations of Parks, sport, recreation etc... to find what you like
