Any idea when http://maps1.arcgisonline.com/ArcGIS/rest/services/USA_Federal_Lands/MapServer will be back up?
Give this url a try: https://services.arcgis.com/P3ePLMYs2RVChkJx/ArcGIS/rest/services/USA_Federal_Lands/FeatureServer/0
Is this layer maintained by Esri? Or some other org?
That must be pretty old, since it uses http and not https. Is this service a replacement?
Here's more description about it: https://www.arcgis.com/home/item.html?id=5e92f2e0930848faa40480bcb4fdc44e
The site is embedded in the JSON string on this website: https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/web-map-printing-with-arcpy-mp.htm#ESRI_SECTION1_1AFE535BEC744EE99B32BF9952173799. Adding the website you suggested into my code is not working in its place.
Yes, it seems to be maintained by ESRI.
That one works! Thank you!!
