Hello,
I want to know How can I change the pin location image in map? I want to give my custom image as shown in image
I'm not sure of the answer but you could try setting the highlight option property on the Map View
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#highlightOptions
You don't say what kind of layer you're using or how you're adding it the map but a picture marker symbol will allow you to specify a custom image.
The Symbol Playground will help you generate the correct syntax.
How to use picture mareker symbol
Can you show where to add picture marker symbol. When I am trying to use it it gives me an error
I haven't tested it out but you could try something like
//create the marker
var marker = {type: "picture-marker",url: "https://arcgis.github.io/arcgis-samples-javascript/sample-data/cat3.png",width: 46,height: 46};
//apply it to each graphic
const peakResults = response.features.map(function(feature) {feature.symbol = marker;}
Hi,It's working, thanksDo you know how to change the picture marker symbol on click the pin image.Like the below image when I click the pin image it should change to dark red marker.
It's working ,thanks. I need few more suggestions.To change the picture marker dynamically after on click.
I believe you need to watch for a click event on the MapView object and get the graphic using a hit test.
This sample should get you started -
https://developers.arcgis.com/javascript/latest/sample-code/view-hittest/
It adds a highlight on mouse-over but you could modify it to change the symbol on click instead.
I tried with the hit test and click event but still it's not working. I will share my code also.
let centroidRenderer = {type: "simple",symbol: {type: "picture-marker",// url: "https://static.vecteezy.com/system/resources/previews/000/582/855/original/vector-location-pin-icon.jpg",url: "images/Location-map.png",width: "26",height: "26"}};
let locationpin = new FeatureLayer({url:"https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Centroids/FeatureServer/0",renderer: centroidRenderer});
let symbol;
view.when(async () => {const layerView = await view.whenLayerView(locationpin);view.on('click', async (e) => {const {results} = await view.hitTest(e);try {const { graphic } = results.find(x => x.graphic.attributes.OBJECTID);if(symbol.url=="images/Location-map.png"){(symbol.url==" https://static.vecteezy.com/system/resources/previews/000/582/855/original/vector-location-pin-icon.jpg")}else{symbol.url==" images/Location-map.png"}// fWidget.graphic = graphic;symbol = layerView.highlight(graphic);} catch(err) {}});});
view.when(function() {map.addMany([locationpin]);});
What is not working? Are you getting an error? Are you not getting any features from the hit test? Or is the symbol not being applied?
The code is now working, But I need help in removing the blue highlight color after clicking the pin image.I am sharing my code.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
