Hi,Thanks for the reply!I am not sure what I am doing wrong. Actually, I also did ESRI`s geocoding "Atlanta" tutorial, and I got the same result; I get an address locator file. when I add it to ArcMap and open the Geocoding toolbar I am able to identify addresses (which are snapped to the street layer. however, I am not able to locate the point layer itself (if there is such one), which has the point address entities stored in the address locator. Where should I see that layer? is it supposed to be added as a regular point layer to the document?What I mean is that the "Locator" file does exist. however, I don`t know where the addresses are stored in it. lets say I open a new ArcMap document and add to it the address locator- is there anyway I can see the point entities stored in it?hope now my question (and misunderstanding...) is clear.tanks!
It sounds like you are expecting to find a table or layer containing all possible address points in your study area, as part of your address locator, is that correct? Street address locators don't work like that.
To oversimplify: When you geocode an address, the locator first finds a street segment with a matching name and range of address numbers that encompasses the address number you're looking for. Then it interpolates the distance along that street segment where that address would be found. So for example, searching for "125 Main St", the geocoder finds a street segment named "Main St.", with an address range of 100 - 199. 125 Main St is 25% of the difference between 100 and 199 Main St so the geocoder calculates a point location 25% along the length of that segment.
So the points you get when you geocode a table are interpolated from the address ranges of the street segments, and calculated on-the-fly as needed. Creating an address locator is basically creating a bunch of compressed tables and indexes that make this process extremely fast. There is no "master" point layer or table.
Apologies if I'm misunderstanding your question.
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
