I am using ArcGIS Pro 2.9.2 on a Windows 11 Dell desktop.
I am having trouble with the Distance and Direction tool. Specifically, the "Line" drawing for Distance and Direction does not create a line using the point-to-point creation tool. After I place the second point, it spins for a moment as if processing, then nothing appears on the map, but the Distance and Direction option to "Delete Lines" becomes enabled as if there is now data on my map that can be deleted. I have also been trying this on a Windows 10 machine on the same version of ArcGIS Pro and I get the same issue.
Something that may help is that I am noticing the "Line" creation tool is not generating a feature class when I place the second point. If I do a circle, ellipsis, or ring, it will create the feature class, but the line will still not display or show up in the attributes table.
I'd share images, but I don't know if any would be helpful as nothing is displaying or getting created when I use the tool. Any help would be greatly appreciated.
