こんにちは、
現在、Microsoft power automateをIntegromat/Makeと同じように使用できるかどうか評価しようとしています。dev summit 2021のビデオで示されているように、integromat/makeで可能な機能レイヤーの属性データにアクセスする機能を得るために、懸命に試みています。特定のフィールドから属性データをメールに含めることができるfeatureupdatesに基づくMakeで完璧に動作するソリューションを展開しました。どのプラットフォームを使用するか評価しているため、何か助けやドキュメントがあれば大変ありがたいです。
よろしくお願いいたします、
https://www.esri.com/videos/watch?videoid=D9PMC2yGJbA&title=getting-started-with-hosted-feature-layer-webhooks
Oh, when you are iterating over the features, I think you can use this expression to get a specific attribute:
item()['attributes']['someField']
For dates, you'd want to format it:
addSeconds('1970-1-1',Div(item()['attributes']?['date'] ,1000),'yyyy-MM-dd')
I haven't tested it but I think these should work.
@NickCressman Yes, this is possible. I've published a blog post that shows how to configure a flow (in the context of ArcGIS Field Maps) that sends an email.
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/use-webhooks-to-automate-workflows-in-arcgis-field-maps-with-power-automate/
BTW, Field Maps has an app in Integromat that greatly simplifies using hosted feature service webhooks. We're still sorting through some issues with the Make support team - it's not working in Make after the migration. Anyway, it's not specific to Field Maps - you can use it for any hosted feature layer that supports webhooks.
@Anonymous User I actually followed your post and completed it. My only question is how do you break out the fields like make. If you look at the image below I can pick what field i want in make to include in my email that I send. This is important as the day of the week assigned is what needs to go out in the notification and day of the week is a field in the layer.
Okay thank you I will have to test that out and let you know.
This did work thanks for the help!
Hi Nick,
I am looking to do the same thing you mention in the thread. Integromat/Make is very easy and the attribute data is easy to choose and move around. Were you able to get Power Automate to the same point? My IT team will not allow me to use Integromat so getting PA to work for a survey would be great.
Thanks
I have been trying to work things out with microsoft but am not having a ton of luck. I would love to use integromat/ make, I am familiar with it and the ease of use. Still trying to work with IT to open up integromat so for now I am stuck with automate.
Well, any questions I would be glad to help.
Here is what my flow looks like I followed a help article as well which is above in this chain.
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
