I am trying to get a MMPK to work with our Quick Capture projects for offline use. I followed the instructions in https://support.esri.com/en/technical-article/000022755.
When I either edited the json OR simply used the mmpk as the linked map I got the same error in the Quick Capture Designer and wasn't able to save it.
Our company does not use Enterprise, I created it in Pro 2.7. I uploaded it to AGOL using the Add New items button and simply selected the created mmpk from my computer and uploaded. Is there a different way to upload this to AGOL so that it works or is this a bug/error and I need to find a different work around (i.e. sideload to device) to get this mmpk available for use with Quick Capture?
