Hi - I have added the Ordnance Survey Terrain 5 Contours Shapefiles to my project. And yet, as you can see in the attached image I have different colours per tile. Is there a way to import in standard format i.e. without different colours per tile.
thanks!
This site talks about this. The Apply Symbology From Layer geoprocessing tool would work.
Also in the symbology pane for each layer you can import symbology from a layer file.
https://pro.arcgis.com/en/pro-app/latest/help/mapping/layer-properties/import-symbology-from-another-layer.htm
Thank you !
