A glimpse of new features in the upcoming March update.
Looking forward to the print option.
Yay! Hopefully the "List supports two dimensions as grid" will close out this idea?
Excited for the print option as well. Thank you ExB team.
What about the time slider widget?
Thank you.
@GEORGIOSCHALARIS, see 2022 roadmap
@Jianxia
I am assuming the update has happened due to some of the issues in the Experience Builder I have ran into today. Thanks for fixing the Zoom to action for the filtering widget, this is now working great for me!
Can you please let me know if the update occurred, and how you may be able to help with the following problems? I have included images of what I can. The application I am building is confidential and I cannot share the whole screen.
1. Dynamic text rounding: There is no clear way to customize the number formatting for dynamic text. Any expressions that utilize division, for example, are not formatted with a thousands separator nor are these numbers rounded. In the figure below, the first occurrence of dynamic text has commas separating thousands, but the remaining are derived with division and cannot be rounded.
2. The Map Layers widget: This widget has move WAY back in its functionality. There is no obvious way to tell which layer is toggled on or off. It is just a bulleted list. Also, the zoom to layer button did not appear when turned on. The old functionality was much better and more intuitive. I have included an image below where the layers that are on have checkmarks beside them, and the layers that are off have 'x' beside them.
3. The Map widget: the Home and Zoom in and out buttons are now words instead of icons. Was this intentional? This isn't usually the standard.
@ANesdoly , the March update hasn't happened yet.
@Jianxia The update is great! There are a lot of features - especially the dynamic text rounding - that have severely improved my application.
@ANesdoly, Glad it works for you and thanks for letting us know.
