can export a model from ModelBuilder to a Python script, but you can’t export a Python script to a model. Explain why you can’t export a Python script to a model
Hello Chelsea,
There is a way to create a script tool inside a toolbox then add it to the model as part of your workflow. See this tutorial: https://pro.arcgis.com/en/pro-app/2.8/arcpy/geoprocessing_and_python/adding-a-script-tool.htm
After you create the script tool, you can add it to your model.
Hope this helps!
Are you using ArcMap or ArcGIS Pro?
hello, Arcpro
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
