I would like to check if featureclass is editable (depending on logged user) without loading featurelayer to map. Where are located priviliges of featureclass displayed in featureclass properties window?
You can see specific role privileges for each dataset Grant and revoke dataset privileges in databases and enterprise geodatabases—ArcGIS Pro | Documentationthis is described in paragaph 'Use the Privileges dialog box'
Sorry, if it was unclear.
I don't want to change privileges. I want to read them from ArcGIS Pro SDK.
No, my fault I misread.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
