Is it possible to grab a toolbox description via arcpy? Or maybe by using another library?
Just about everything but
import arcpy pth = r"C:\arcpro_npg\npg_tools.tbx" t0 = arcpy.ImportToolbox(t) arcpy.Usage(t0) tools = arcpy.ListTools(t0) for tool in tools: print(arcpy.Usage(tool)) # -- AttributeSort_npg({Tool}, Input_features, Sort_fields;Sort_fields..., {Output_field}) ... snip ... Triangulate_npg(Tool, Input_Features, Output_Features, {Polygon | Polyline}, {True | False}) # -- t1 = tools[0] help(arcpy.AttributeSort_npg) Help on function AttributeSort: AttributeSort(Tool=None, Input_features=None, Sort_fields=None, Output_field=None) AttributeSort_npg({Tool}, Input_features, Sort_fields;Sort_fields..., {Output_field}) Sort by attributes. INPUTS: Tool {String}: Tool being used. Informational only. Input_features (Table View): The feature attributes to sort. Select a layer if prior selections are to be honored. Sort_fields (Field): Fields to sort on, in order of importance. Output_field {String}: The field to create to contain the sort results.
arcpy.Usage() works great after importing the toolbox, thanks!
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
