ArcGIS Online でダッシュボードを作成しています。ダッシュボードにセレクターを追加したところ、すべてのチャートを正常に絞り込めるようになりました。しかし、セレクターの対象としてマップを追加できません。マップも絞り込むには、これらのセレクターをどのように使えばよいですか?
You should be able to filter individual layers from the map. When adding a target to the selector's filter action, just look for the map, and then select an individual layer from within the map.
Do you just not see any map layers as available targets? Can you provide a screenshot of what you're seeing?
Hi Josh,
I'm not seeing the map displayed under the Add Target drop down.
Strange! Is the same data being pulled into the various charts?
Also, is the map data coming from a Feature Service or a Map Image Service? The latter may support data access for charts, but will not support spatial operations in the map, and I've had trouble getting Map Image layers to "play nice" with Dashboards.
Yes, the charts and the map are all reading the same Feature Layer (hosted). I did create all of the charts prior to creating the web map and adding it into the dashboard though. Could that be the issue?
Is there a setting on the Feature Layer itself that needs to be enabled? I wouldn't think so seeing that I can add the same map to a web app and create filters within it that work fine. Just cannot seem to manage it within the dashboard.
Your selector is pointed at the layer itself, not the map's layer? It really shouldn't matter, as I'm able to have a selector act against any other layer in the dashboard, map or not.
Try recreating the selector, but choose the map layer as the source layer for its values.
When choosing the layer for the selector, it states "The map doesn't contain layers that can be used." But it does show the desire layer under the "Stand-alone layers' section. Looks like I may need to check some settings, but I do feel like I'm making progress! Thank you!
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
