All.
Is there a way I could use the URL parameter (ex: year ) to tell filter widget to pick the right layer to do the filter on ? Is it even possible ? Thank you.
Is there a reason you need to us a URL parameter? You can set the filter widget to use expressions determined by the user.
The idea is to have it automated as much as possible for users. Users will open the app from a hyperlink in other app. When my app opens it's zoomed to the selected polygon (through URL parameter) . Now having multiple years to the app makes it tricky. Thanks.
Not possible OOTB afaik. Will need custom coding
Thanks @vtey_esriau .
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
