var mapDeferred = new esriUtils.createMap('ec7080edfb7c4197989dee3c6207264c', 'map1', { mapOptions:{ basemap:"streets" } });
var baseMapLayer = new ArcGISTiledMapServiceLayer("http://services.portlandmaps.com/ags/rest/services/Public/Basemap_Gray/MapServer"); map1.addLayer(baseMapLayer);
require(["esri/layers/ArcGISTiledMapServiceLayer", ... ], function(ArcGISTiledMapServiceLayer, ... ){ ... });
map1.setBasemap('topo');
Hopefully you find the answers you seek; I wish I could be more helpful!
//get title of basemap var currentBasemapName = webmapResponse.itemInfo.itemData.baseMap.title var bmNameEqiv = bmDict[currentBasemapName ]; esriMap.removeLayer(webmapResponse.itemInfo.itemData.baseMap.baseMapLayers[0].layerObject); //just reset the base map so we can use setBaseMap later esriMap.setBasemap(bmNameEqiv);
Thanks for the answer, which is still helpful three more years later. This solution fixed the problem that setBaseMap cannot recognize the basemap from web map.
I think the possible mechanism of setBaseMap() might be: Delete the basemap of map.basemapLayerIds, and then import the new one.
I had a similar problem setting the basemap using map.setBasemap and stumbled on this thread. After a bit of investigation I discovered that when using a webmap the map object holds a reference to the initial basemap as 'defaultBasemap'. You can see that by examining map.layerIds. As long as that layer remains in the map, setting a new basemap with `map.setBasemap('topo')` will not work properly. The new layer gets added, but the 'defaultBasemap' layer remains. The easiest solution is removing the 'defaultBasemap' layer just before setting a new basemap. Here's how I achieved it:
<SPAN class="keyword token">const</SPAN> baseMap <SPAN class="operator token">=</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">getLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'defaultBasemap'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN><SPAN class="punctuation token">(</SPAN> baseMap <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">removeLayer</SPAN><SPAN class="punctuation token">(</SPAN>baseMap<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setBasemap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'streets'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
