Is it possible to have two scale bar widget styles displayed? I want both ruler and number.
You should be able to add multiple scale bars, but not without getting into some custom JS coding.
I think you can modify themes that you use (themes folder) or config.json on root folder if your app is already create. Try to duplicate the part of scalebar widget and modify the position.
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
