こんにちは - 2021年9月初旬のアップデート以降、ArcGIS for Power BIが正常に動作していません:新しいマップではマップがまったくレンダリングされず、既存のマップではシェイプファイルが正しくレンダリングされません。<\/P>
Power BI内で手動で古いArcGISバージョン(丸いアイコン?)に戻す方法はありますか?<\/P>
To add: the shape files are census tracts.
PowerBI version 2.96.1061.0 64-bit (August 2021)
ArcGIS maps for Power BI version 2021.1.91
@hellomynameisjoe Thank you for posting, I am sorry to hear that you have been running into issues with the latest release of ArcGIS for PowerBI. According to the Product team, a new version of the app was pushed that resolved many of the issues with the September update. Could you ensure that you are running on the latest version to see if the issues still persist? Thanks!
Hi @JonEmch :
I upgraded Power BI to 2.97.861.0 64-bit (September 2021). The ArcGIS Maps for Power BI is 2021.1.91.
The problems continue!
I'm unable to create new maps using census tracts (see attached image) and existing maps render poorly.
Please help me keep on keeping on!
Any short term fixes? Any way to revert back to older ArcGIS versions?
I was getting the same error "The Provided Data failed to generate a layer on the map" because I had a date field in my tooltip, and when I changed it from a date hierarchy to a date, it broke. Changing it back to the date hierarchy fixed it. My workaround (I wanted to show the date, not the hierarchy) was to use a DAX Convert function to convert it to a string.
Appreciate your suggestion.
Unfortunately, I don't think this fix applies to my issue.
Esri team - help!
@hellomynameisjoe - Hello there! My name is Anthony and I am a product engineer on the ArcGIS for Power BI visual. I was looking over this issue and I would like to help out if I can!
Would it be possible to provide the data that you are using in Power BI so that I can test it on my end? There might have been a change in how the data is processed during this upgrade. If there is in fact a BUG or an issue with this, I can add it to our upcoming project and have it looked at by our team.
I had a look at the screenshots and I agree; something isn't quite right with that data. I would like to do a comparison between this version and the previous to see where the gaps are.
Unfortunately, there isn't a way to roll back to the previous version of ArcGIS for Power BI.
Let's try and get this resolved for you!
Andrew,
Thanks for the update. I see that one of the issues is fixed and I can thematically display Census Tract data however the rendering is still an issue - see attached image. And it is also 2010 tracts, will they be updated to 2020 soon?Rendering of Census Tracts
That's really odd that the geometry isn't resampling, we'll have to take a look and I can follow up on the Census Tract updates. We should have those in place.
Hi @Anonymous User: I'm on the latest version of ArcGIS Maps (2021.2.95) and PowerBI Version: 2.99.862.0 64-bit (November 2021).
I'm unable to render any map visuals. When I drag in Census Tracts:
1. Nothing renders (I've also tried zip codes and counties, but no luck).
2. I'm unable to change the location type (see attached image). I can change the "Represent locations as" from Points to Boundaries, but am unable to change "Locations are in".
I've uninstalled and reinstalled Power BI, but this issue persists.
Any ideas?
I'm unable to reproduce this, but may be following different steps. Would you be able to send a .pbix file with me so we can review it?
