Hi All,
Just wondering when study materials and learning pathways might be released on the ESRI Academy for the ArcGIS Pro Associate 2101 beta exam/cert?
ArcGIS Pro Associate 2101 | Technical Certification (esri.com)
Many thanks,
Ben
The exam is currently in Beta Testing phase. One could expect the Learning Plan, once the exam is available for public (usually takes around 3 months from the date of commencement of beta testing).
Also the Exam Information Guide will get updated (Exam Resources to be added).
Hi Josh, there are no plans for practice tests to be developed. However, we recommend you use the Exam Information Guide to review all the concepts you should know, and use the corresponding learning plan on Esri Academy to refresh your skills in concepts related to the exam. For the ArcGIS Pro Associate exam, here is the info:
Will you all be releasing practice tests for the new exams?
Hi Ben,
@JayantaPoddar is absolutely correct here. Our final exam information guide and Learning Plan will be released with the operational version of this exam which is expected in late December 2021. We will share exam launch information here in the Esri Community, so I encourage you to check back often.
Jessi
